| | | Forums66 Topics128,076 Posts1,055,920 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 5 bolter | | bolter Joined: Sep 2012 Posts: 5 | I receive a stock 235 water pump ( for free ) but the pump that's on my 235 engine in a 1939 master deluxe has the short water pump. I would like to press the hub down on this pump to make it a spare pump. Could someone here who has done this before tell me what the measurement is I would need to to lower the hub ? Any help would be greatly appreciated. All I need is a measurement........
Once I thought I was wrong, but I was mistaken.....
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | pkr....can you not measure the one in the '39? I pressed one down a few years ago but do not know the measurements. After all the hassle pressing it I found out I could get one from O'Riellys as a very good price. I bought a new one and gave the other one away....think about it. Good luck.
EDIT: my notes indicate I bought a water pump from O'Rielly's part # MWP 58-126 for $47 dollars. That was 4 years ago. Double check and good luck.
