3 members (tesa, Bill Hanlon, Gray_Ghost), 76 guests, and 0 robots.
Topics128,076
Posts1,055,925
Members48,430
#1385249 11/20/2020 1:36 AM
Moderated
Moderated
I am in the middle of upgrading my tie rods and tie rod ends since mine are pretty bad. I am thinking about getting new steering arms as well. Does anybody know a place to buy them? No luck in the local junk yards, and I can't seem to find them in the place I know of online. Thank you.
1/2 ton, 3/4 ton, 1 ton or larger. Chevy or GMC? We always need the full story.
Crusing in the Passing Lane
I have looked for steering arms, the part that bolts to the spindle, never could find a PN, apparently they are not sold separately.
Ed
Ed
The "Steering Knuckle Arm and Steering Arm's" are found in Group 6.103
55-59 1/2 ton Steering Knuckle Arm...(forged 3711777)....p/n 3711883
55-59 1/2 ton Steering Arm.....p/n 3755045
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
I have not seen any of them aftermarket. Those parts have to be removed from the axle to be able to remove the ball. Clean them up and you will probably find that they are OK. They are solid components and the only wear area is the ball. Unless they have been damaged in a wreck. The new type tie rods are a big improvement.
Fred
