3 members (Hotrod Lincoln, Steve_H, 1 invisible), 139 guests, and 3 robots.
Topics128,149
Posts1,056,814
Members48,454
Has anyone purchased a complete set of the fender trim and spears from Jim Carter Truck Parts? Wondering how well they fit on original fenders. Does installation instructions come with them? They look nice in the pics.
1 Offline
As far as I know none pieces have been out to the public yet.
ok, thanks
Hello everyone, I talked Julie at JC yesterday about the fender trim. As of now there's no word as to when the trim will be available.
Chevytruckdaddy
thank you for info
Dave
I recently purchased 2 pieces pass rear fender upper and middle...they are dead on match as opposite side...but still on back order...reason being....was told..prototype needed adjusting??.anyway when there ready to produce @$1550.00 a set people will be very very satisfied...no dates as of yet...
Rear Mouldings should follow body contour.
That's how the factory mouldings were made.
The hand made aftermarket mouldings usually do not follow body contour.
Lower pieces run short. Like in a straight line.
Picture of rear mouldings,
Left side is almost dead on.
Right side is a little off.
The way the front fender is shaped compared to the rear fender, makes it easier to make the pieces for it.
At any rate the higher quality re-popped lower front & rear fender mouldings should follow the body contours.
For what some folks are asking for their original pieces I think I can be satisfied with somewhat less than "perfect". There are some things I just can't justify and I don't like being taken advantage of.
I have met and talked to Jim Carter on several occasions over the past 18-20 years and greatful he has invested in this venture. Perhaps the metal itself may not be somewhat thinner but Jim has produced some good stuff....like the very nice panel gas tank he had repoped two or three years ago, which is Very Good.
...that being said, I'll wait for the re-pops if I decided to put the trim on.
Here is an Example of Badly made aftermarket Fender Mouldings
Note: No front fender upper spear.
I am sure when Jim Carter's mouldings come out, they'll be nothing but top notch.
I know this is a really old thread but I keep contemplating the idea of getting a set of these trim pieces for my truck. I am sure at least a few of you have done this, how was the fit?
Joe
1955 First Series 3100
Have you sent a PM to Mother.Trucker ?
Have you sent a PM to delux54panel ?
Ask them to send you photos and/or email addresses for a satisfied customer.
** Purchased the fender mouldings & spears from Jim Carter about a year ago for the 53 Suburban I'm doing a full frame off restoration on. They fit very well & very simple to install. Both come with directions to install. Looks great.
Thanks, marzach
I know this is an old topic, but can someone post the installation instructions or templates?
Contact marzach above, and he may share the instructions. You know we never throw stuff away!!
Here are some pics of what I have saved that others have shared…..
Thank you elhippie64
