| | | Forums66 Topics128,193 Posts1,057,249 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | Hello all,
Jumping over from the Big Bolt thread, I asked for a rear Hub grease seal part number for my 1.5 Ton 46 with single speed diff. It has been mentioned the book has two part numbers one for a "Splined Hub" and "Unsplined" hub. Could someone please explain this difference as several vendors only list one seal with no mention of it.
Thanks | | | | | Joined: Feb 2004 Posts: 29,878 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,878 | Some hubs have a metal cover bolted over the axle, with teeth resembling a gear on the axle flange and corresponding gear-shaped female teeth in the hub. Other axles have conventional flanges that drive the hub with bolts or studs. If your hubs have a bolt-on sheet metal cover over the axle flanges, you've got a "splined hub". Jerry
| | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | Got it, I have the conventional style hubs.
