2 members (Stovebolt48, Hotrod Lincoln), 146 guests, and 1 robot.
Topics128,190
Posts1,057,339
Members48,469
#138293 06/02/2007 2:03 AM
Hi All,
I have a pair of 283 heads that have the pyramid symbol on the ends of the heads. The number is 3884520. I am told they are 55cc powerpack heads from around the mid to late 1950's. If this is correct, are they valuable? I know that in the performance world even the camel hump heads are old news but I wonder if these have any collector value. What do you think?
Rick
#138294 06/02/2007 2:43 AM
a google search indicates they have a 60cc chamber and were on 283s from 1960 to 1967.
http://www.mortec.com/castnum.htm
cheers,
mv
46 Chev One Ton Panel - S10 Frame Project
"What if the Hokey-Pokey is REALLY what it's all about?" - J. Buffet
#138295 06/02/2007 2:47 AM
every early sbc head in my large pile has the pyramid - and as Mike sez, that number reads as 60-67 283/327 .... the "collector value" would simply be if someone wants the particular casting mumber for their 100 point resto .... I collect them for $0 grin
#138296 06/02/2007 3:04 AM
They seem to be pretty common. They are on my 59 that had a 283 swapped in it. I have used the casting numbers to determine it is a 64 or 65 motor.
R-Bo
1966 GMC 305V6 in the family
#138297 06/02/2007 9:18 PM
Thanks for the info, and thanks for the mortec site! Well it looks like I will be keeping my job after all, I won't be getting rich off these heads! Thanks for helping.
Rick
#138298 06/03/2007 10:56 AM
they are 4 barrel heads if they didnt have the perimid they would have been 2 barrel heads
#138299 06/03/2007 11:21 AM
knuckle head
knuckle head
Mid 60's 195 hp 2bbl 283's had those heads as well as 250 hp 4bbl 327's.
#138300 06/03/2007 6:07 PM
They would be worth more if you had the rest of the engine under them, LOL,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
