| | | Forums66 Topics128,036 Posts1,055,450 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | All things considered, will a power steering gear box work properly if it is laying on it's side? Specifially a 70-80s chevy pickup box. | | | | | Joined: Mar 2007 Posts: 3,374 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,374 | It should, after all it's only a worm gear drive. The big question is how would you mount it solidly and will you have enough clearence. There is a lot of stress on the mounts when bolted up as is, it would take a BEEFY mount to make it work properly. Just my thoughts.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | I'll have to create some sort of strong mounting pad, that is for sure. My thoughts are to mount one on a cabover where I would need the arm in a different location and swing radius. The columns in those are so vertical that a traditional type mount would just swing back and forth (like a windshield wiper) rather than to and fro action. I haven't even thought about mounting yet...That happens once i know it can be rotated. I agree that it should, but I wasn't that familiar with the internal workings of the box.Thanks. | | | | | Joined: Mar 2007 Posts: 3,374 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,374 | Have you looked at something different, a cabover like an Isuzu or a GM stepvan. Many of those had vertical columns with straight axle's. Old bread trucks are everywhere.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Hey, that is a thought. One problem is going to be space. The original box is crammed into a tiny spot, and they are little to begin with. I'll have to check out the Isuzus and see. I know a guy who has one..Thanks | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | You may have a problem getting all the air out if you turn one upside down.
I agree, there are plenty of better suited boxes out there, find one that does what you need without much modification.
Grigg | | |
