Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (NJC, Wayne67vert, 1 invisible), 166 guests, and 4 robots.
Topics128,281
Posts1,058,471
Members48,490
#1379743 10/06/2020 2:35 PM
I have a 1950 3100 with a 261 in it. It is a 12 volt system with a single 1 barrel carb. Sometimes when I turn it off it keeps running for a few seconds. I noticed that it doesn't do this when I have the A/C compressor on. Does anyone have any suggestions?
Mike
P Online: Content
Curb idle solenoid
Riding in the Passing Lane
Check for a vacuum leak. Slow the idle speed adjustment down. If that doesn't solve it install an idle speed solenoid like Panic says.
George
1972 Chevy c10 Cheyenne Super
H Online: Content
Dieseling is usually caused by a too-lean idle mixture and too high an idle speed. Go a little richer on the idle mixture screw (counterclockwise), and turn the speed down so you can almost count the fan blades as they turn. Unless you've got a radical camshaft and/or a vacuum leak, the engine should idle down to less than 500 RPM.
Crusing in the Passing Lane
If the throttle is not closed all the way, this will occur, idle speed adj. as above.
Ed
