1 members (Cosmo), 84 guests, and 3 robots.
Topics128,054
Posts1,055,779
#1378990 09/30/2020 1:55 PM
' Offline
So I'm picking away at the little problems on my '37 1/2 ton. The glove box is open but the lock is locked so it won't stay shut.
Is it possible to get a key made or what would you all do? I removed the door and am trying to remove the lock w/o wrecking
anything. It appears there is a little piece of spring steel that must be depressed but it still won't come apart.
Maybe I'll post in the swap meet forum and see if anyone has a lock and key.
You may want to check with a lock shop ,it is something that you can take down to there shop so shouldn’t be to expensive .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Ex Hall Monitor
Ex Hall Monitor
Pictures would help. The how-to is at the bottom of the left column.
A locksmith can cut the key, just take the whole thing in and they get it apart. The lock will numbered, at least mine was.
' Offline
So I took your advice and took the glove box door to a locksmith. He will make me a couple keys for $35.
I made more of a problem out of that than I needed to.
That's how we learn! smile Glad you got it figured out.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
