| | | Forums66 Topics128,049 Posts1,055,679 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2019 Posts: 131 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 131 | So I'm picking away at the little problems on my '37 1/2 ton. The glove box is open but the lock is locked so it won't stay shut. Is it possible to get a key made or what would you all do? I removed the door and am trying to remove the lock w/o wrecking anything. It appears there is a little piece of spring steel that must be depressed but it still won't come apart. Maybe I'll post in the swap meet forum and see if anyone has a lock and key. Thanks John | | | | | Joined: Sep 2010 Posts: 2,307 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,307 | You may want to check with a lock shop ,it is something that you can take down to there shop so shouldn’t be to expensive . | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Pictures would help. The how-to is at the bottom of the left column.
| | | | | Joined: Feb 2000 Posts: 5,200 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,200 | A locksmith can cut the key, just take the whole thing in and they get it apart. The lock will numbered, at least mine was. | | | | | Joined: Oct 2019 Posts: 131 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 131 | So I took your advice and took the glove box door to a locksmith. He will make me a couple keys for $35. I made more of a problem out of that than I needed to. | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | That's how we learn!  Glad you got it figured out. | | |
