| | | Forums66 Topics128,093 Posts1,056,046 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2020 Posts: 13 New Guy | | New Guy Joined: Jun 2020 Posts: 13 | I found a GMC 5 window cab and front clip. Both in good condition. I was wondering how to tell the difference between the Chevy and GMC 5 window cabs. I cant find anything out there that says there different and if there is a difference what it might be.
Kosanow1
| | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | Welcome, and good question. What year cab and clip? I guess you know the differences between 47-53 and 54-55-1st series? The 47-53 had different speaker grilles and different gauges between Chevy and GMC. Of course those can be changed/swapped. The 54 and 55-1st series GMC had an entirely different dash from Chevy. https://www.stovebolt.com/gallery/images/hoover_dave_1954c.jpg
Professional Novice
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Frank50,
That is a '54-'55 panel for kosanow1's info. The engines are different, if one is in it.
Ed
| | | | | Joined: Jun 2020 Posts: 13 New Guy | | New Guy Joined: Jun 2020 Posts: 13 | It's a 47-53 I think. It has the same gauges my 52 GMC has. The interior looks just like my 52. It also has the block (no head) of a 228 still in it.
Kosanow1
| | | | | Joined: Jun 2020 Posts: 13 New Guy | | New Guy Joined: Jun 2020 Posts: 13 | Thanks for the help. I'm trying to decide if I need another project.
Kosanow1
