0 members (), 44 guests, and 4 robots.
Topics128,077
Posts1,056,013
Members48,433
#1378709 09/27/2020 10:06 PM
I have about 2 hours of break in time and about 1 hour drive time on the oil with break in additive in a fresh 261 . Is it recommended to change the oil before putting on another 500 miles or so or will it be ok to keep on keeping on ??
good planning is no substitute for dumb luck
panel fan #1378711 09/27/2020 10:37 PM
H Online: Content
"Break-in" beyond the first 100 miles and maybe 10 full throttle accelerations in high gear to seat the piston rings is a myth. The machining procedures and quality control on parts made in the past 50 years or so are far more accurate than the engines we tinker with were when they were brand new. Drive that engine a couple of thousand miles on the oil that's in it now, and start changing the oil and filter at whatever interval you choose- - - -the engine won't care, and it will probably outlast a brand new one from the 1950's.
panel fan #1378772 09/28/2020 12:58 PM
Thanks Jerry I'll run it as is until I put it away for the winter with fresh oil .
