1 members (UtahYork),
80
Mod | | | Forums66 Topics128,049 Posts1,055,637 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 39 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 39 | stupid me. i lost the stainless gas cap for my 1955 ist series 3100 pickup. anybody know where i can purchase an original style cap? thanks in advance. jim | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jan 2017 Posts: 23 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 23 | Make sure its vented. I had to get a new cap and pressure built up and fuel started pushing out through the sending unit on the tank lol!
1954 3600
| | | | | Joined: Jan 2020 Posts: 620 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 620 | Same thing happened to me. Don't do what I did. I wanted to get an original GM locking cap. Would not fit because I found out the car has a different size filler tube. Rats! Doc.
| | | | | Joined: May 2009 Posts: 135 'Bolter | | 'Bolter Joined: May 2009 Posts: 135 | Local parts store should have a suitable cap. Tell them that a Stant 20 or 23 interchange is what you need. Most current caps have a flat spot on them for whatever warning sticker is required.This means they do not look like the original cap. Some restoration vendors might have a domed cap. Or watch eBay.
Mike | | | | | Joined: Aug 2019 Posts: 251 'Bolter | | 'Bolter Joined: Aug 2019 Posts: 251 |
1957 Chevy 3200Daily DriverPS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights/backup lights/interior courtesy lights. Follow in the DITY | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Your local auto parts should have one on the shelf
Try asking for a 6023
Unfortunately I think you will find that the new vented gas caps do not vent properly, I ran into that issue and believe the springs on the check valves are to strong. | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | My experience after losing my original was that the aftermarket had a slightly different contour in that they had a flat face vs. the rounded face or they fit too tight to whatever. Tried several...Jim Carter had a perfect replacement and it has served me well since. | | |
