0 members (), 52 guests, and 0 robots.
Topics128,050
Posts1,055,643
#1377047 09/14/2020 9:48 PM
stupid me. i lost the stainless gas cap for my 1955 ist series 3100 pickup. anybody know where i can purchase an original style cap? thanks in advance. jim
gmman4 #1377049 09/14/2020 10:02 PM
gmman4 #1377428 09/17/2020 4:06 PM
Make sure its vented. I had to get a new cap and pressure built up and fuel started pushing out through the sending unit on the tank lol!
1954 3600
gmman4 #1377506 09/18/2020 1:42 PM
Same thing happened to me. Don't do what I did. I wanted to get an original GM locking cap. Would not fit because I found out the car has a different size filler tube. Rats! Doc.
gmman4 #1378132 09/22/2020 11:08 PM
Local parts store should have a suitable cap. Tell them that a Stant 20 or 23 interchange is what you need. Most current caps have a flat spot on them for whatever warning sticker is required.This means they do not look like the original cap. Some restoration vendors might have a domed cap. Or watch eBay.
Mike
1936 1-1/2 Ton (RD) Stake Body Original
gmman4 #1378136 09/22/2020 11:14 PM
1957 Chevy 3200
Daily Driver
PS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights/backup lights/interior courtesy lights.
Follow in the DITY
gmman4 #1378150 09/23/2020 12:50 AM
Your local auto parts should have one on the shelf
Try asking for a 6023
Unfortunately I think you will find that the new vented gas caps do not vent properly, I ran into that issue and believe the springs on the check valves are to strong.
gmman4 #1378172 09/23/2020 1:58 AM
My experience after losing my original was that the aftermarket had a slightly different contour in that they had a flat face vs. the rounded face or they fit too tight to whatever. Tried several...Jim Carter had a perfect replacement and it has served me well since.
