3 members (Gray_Ghost, Steelonsteel, Gdads51), 46 guests, and 1 robot.
Topics128,090
Posts1,056,024
Members48,432
#1376984 09/14/2020 6:38 AM
Hello folks!
I've got a 1965 GMC panel van with a Stovebolt 235 . It's been sitting awhile as it was my Great Grandfathers. My Dad drove it and 12 years ago parked it on the farm and now she's seized up.
Drained all fluids, added some mystery oil to cylinders and what not but cannot find a good way to turn the crank from the front near the fan.
I've heard you can take off the starter and pry on the flywheel but I'm looking for some more advice first!
Anyways I've been looking at this site for awhile and I cannot wait to hear this 6 cylinder purrr
1965 GMC Panel Van
1965 GMC Panel Van
In Panels & Burbs
Good morning, Whimpy, and welcome to Stovebolt. Congrats on the GMC panel truck.
FYI- for questions and answers the best place to ask them is in the garage forums. Your current questions would be best asked in the Engine forum, or perhaps the General truck forum.
....but I will add that there are many ways to free up and old engine. Along with what you have done, buy a flywheel wrench that you can put on the flywheel and help spin the motor. They aren't expensive and you'll use it more than thank you think. you can pry on the flywheel with a big screw driver but you don't want to brake anything!!!
Some folks use 50/50 mixture of transmission fluid and diesel fuel and many other concoctions. Its a slow process but can be done with patience.
I will add that I had a 261 engine that I ended up pulling the head and "pounding" on the pistons to get it freed up but hope you don't have to do that.
Former Workshop Owner
Hello Whimpy,
Alvin is correct, you'll get more and quicker replies by posting in the appropriate forum.
That said, if your van has a manual transmission you can put it in 1st or reverse gear and slowly try and rock it forwards and backwards.
Welcome to the Stovebolt.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
Welcome to the Stovebolt madness. There is no cure! shake
‘65 GMC should not have a 235. If it does, somebody has been monkeying with it.
3850817 is on my bloxk says its 230-250
3859381 is on the headers idk if you can help me find out what it is then ?
1965 GMC Panel Van
In Panels & Burbs
That is awesome I will be trying the rocking method then !
1965 GMC Panel Van
In Panels & Burbs
Welcome,
Wouldn’t hurt to take valve cover and side cover off and put a little mystery oil by valves and lifters
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
whimpy
1965 GMC Panel Van
In Panels & Burbs
Whimpy #1377077 09/15/2020 12:49 AM
This place has a heap of great information. Check out the tech tips pages too!
1950 Chevrolet Model 1314
In Project Journals
Whimpy
3850817 is a 230 or 250 cast number if I can read the grease properly.
"The Journey"
Follow in the DITY
whinpy the panel truck
There sure is a lot of real estate on top of those panels and suburbans!!
Another quality post.
Real Trucks Rattle
Cleaned out today gunna need some new front floor pans rockers and front fenders but she's loooking good 👍
Unconventional Thinker
Cool project. A little rough but not bad. Have never seen one with the small windows behind the doors.
Shane
Shane's Toys...
2007 Forester XT Limited (2nd Owner)
1991 Cherokee Laredo (2nd Owner)
1981 Chevy 3/4 Ton Fleetside 8,600 Camper Special (3rd Owner)
1965 Chevy 3/4 Ton Fleetside (3rd Owner)
Yea me either it came factory like this was a alberta parks ranger truck
1965 GMC Panel Van
In Panels & Burbs
#1508867 07/12/2023 11:55 AM
AD Addict & Tinkerer
Looking good.
Phil
Project Journals
Stovebolt Gallery Forum
