| | | Forums66 Topics128,082 Posts1,055,964 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I thought I was ready to order my tranny. I called Phoenix Trans over in Weatherford (near Ft. Worth) and was told that before ordering I need to let them know what speedometer I would be running. I had not planned on making that decision of orig. or digital or whatever yet. I guess I will now. Anyone have a suggestion of what speedometer would work better with the 700 tranny?
~Jim
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | If you have a choice of electronic or mechanical I'd start on the other end. What do you want to look at in the cab?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I would get a mechanical drive. There is a large selection of gears that are easy to change in those. Calibrating it is very easy. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I think both mech and elect I've seen look very good and I wouldn't mind either. My main concern is ease of setup and toughness.
~Jim
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | What kind of induction are you running? If you're running EFI that requires a speed signal you'll have to have the support for the electronic anyway. Might as well run the speedo to go with it.
Otherwise I'm a fan of the mechanical approach personally.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | 4 barrel carb. I was afraid of EFI because of the electronics required. I'm from the old school (1 room schoolhouse) and am more comfortable with a carburetor.
~Jim
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Mechanical speedo then. Anything else would not be old school!
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jul 2006 Posts: 23 Junior Member | | Junior Member Joined: Jul 2006 Posts: 23 | If you want to stay old school, then you need a T350. 700R4's require electronics to control the torque converter lockup. The current crop of electronic speedos are alot simpler to cal. than changeing gears, all you have to do is drive a measured distance( Mile Marker) and hit a dip switch. | | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | Check these gauges out http://www.speedwaymotors.com/p/1106,421_5andquot;-Programmable-Electric-Speedometer.html And as far as the trans torque lock up Ive seen a few companies that offer a kit for that http://www.southernrods.com/categor...n/lock-up-kits/products/product-632.html or http://www.jetchip.com/products.asp?pid=14475 My ECM controls my 700R but when I was trying to figure out to go with EFI or a Carb set up I was looking to go that way Hope this helps Todd Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | So Todd, which one did you use? Jim
~Jim
| | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | Jim I went with EFI and lucked out... the ECM that came with my Fuel injection kit controls the torque converter lockup, But.. either kit would work out nice too, "Those gauges are sweet huh ?" I think that's the way i'm going to go
Todd Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Right, I will be getting those gauges. Todd, your pictures show a carb on your engine. Did you switch to EFI after the pictures? Also thanks for the link on the lock up kit. I'll be ordering that asap.
~Jim
| | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | That's a GM throttle body "TBI" I installed that same set up on my 86 C20 W/454 and even went as far as Installing two GM in tank fuel pumps (dual tanks) it worked out so good I had to put one on the 51, I got a 87 blazer 25 gallon with in a tank pump for under the bed I think it will work out cool Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | 87 Blazer, good that's on my list now.
~Jim
