0 members (),
54
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | I was asked to assist a young lady who purchased a 1 ton AD (49 I think) She is having issues with the rear passenger side brake locking up. Thoughts?
Chris | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Chris, tell allabout the truck, how long sitting, any recent brake work done, etc, let her get in here do she can 'learn the language'.
Ed
| | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | She is responding, but her comments need to be approved due to being new.
Chris | | | | | Joined: Aug 2020 Posts: 11 Green Girl and her 1949 3/4 Ton Tater Tot | | Green Girl and her 1949 3/4 Ton Tater Tot Joined: Aug 2020 Posts: 11 | Trying this again... Hi.. my name is Pam, I am the new owner of a 1949 Chevy 1 ton truck. Her name is Tot... like in Tater Tot. I took her out for a drive last week and the back passenger brake locked up. So I was able to put her in reverse and get her out of harms way. I was then able to make it back to the house safety. Any help would be greatly appr3ciated! | | | | | Joined: May 2015 Posts: 11,052 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,052 | Rear brake locking up is probably oil soaked shoes, caused by leaking axle bearing seals. You would think that greasy shoes wouldn't grab, but they definitely do.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Aug 2020 Posts: 11 Green Girl and her 1949 3/4 Ton Tater Tot | | Green Girl and her 1949 3/4 Ton Tater Tot Joined: Aug 2020 Posts: 11 | Hello All you Stovebolters!!
So I have a new to me 1949 1 Ton Chevy Truck! She was shipped down from Salt Lake City, 3 weeks ago. I took her out for a short drive and I think that the back passenger brake locked up as I was pulling out of a drive. I was able to put her in reverse and park her out of harms way. With her in reverse it released the brake. I was able to make it home safely. So what’s a girl got to do? Thanks for your input! | | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | Does a 1 ton have a star screw in the back To back the pads off like the 1/2 ton so we can take the drum off? If not, what am are we looking for and where? Sorry, first time dealing with a 1 ton truck.
Chris | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | On a one ton’s rear, on either side where the brake line enters the wheel cylinder on the backing plate, there are 2 hex heads. These run through the backing plate and are used to turn the toothed adjuster for the shoes on the inside. In my opinion, these are soooooo much easier to work with than the stupid little hole you have to stick your brake tool/screwdriver in, then fiddle/guess which way to turn to back off. | | | | | Joined: Sep 2010 Posts: 2,307 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,307 | Emergency brake cable if used may stick and is difficult to go forward but does go backwards easier.1 ton may be different than a half ton | | | | | Joined: Aug 2020 Posts: 11 Green Girl and her 1949 3/4 Ton Tater Tot | | Green Girl and her 1949 3/4 Ton Tater Tot Joined: Aug 2020 Posts: 11 | Thank you for your input!! | | | | | Joined: Mar 2019 Posts: 119 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 119 | A leaking wheel cylinder can also cause this type problem. The brake fluid contaminates the brake shoes and makes them grab.
Rusty
| | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Can the rear drum on a 1 ton be just pulled off once the wheel is removed like on a 1/2 ton or is there some retainer to prevent that? If no retainer then just pull the drum and see what it looks like.
Ed
| | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | We drove it today. No issues until Pam used the parking brake, then it was all problems after that.
Chris | | | | | Joined: Sep 2010 Posts: 2,307 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,307 | Just curious does the parking brake have a leaver by the shifter and does the parking brake use a drum Separate from the rear brakes. | | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | I didn’t get to look at it. | | |
