5 members (artinva, Rich'sToys, Shaffer's1950, Chip O, JakeM), 116 guests, and 3 robots.
Topics128,072
Posts1,055,903
Members48,429
#1376064 09/05/2020 11:19 PM
I was asked to assist a young lady who purchased a 1 ton AD (49 I think) She is having issues with the rear passenger side brake locking up. Thoughts?
Chris
ndkid275 #1376068 09/05/2020 11:51 PM
Crusing in the Passing Lane
Chris, tell allabout the truck, how long sitting, any recent brake work done, etc, let her get in here do she can 'learn the language'.
Ed
ndkid275 #1376093 09/06/2020 2:59 AM
She is responding, but her comments need to be approved due to being new.
Chris
ndkid275 #1376094 09/06/2020 3:14 AM
Green Girl and her 1949 3/4 Ton Tater Tot
Trying this again... Hi.. my name is Pam, I am the new owner of a 1949 Chevy 1 ton truck. Her name is Tot... like in Tater Tot. I took her out for a drive last week and the back passenger brake locked up. So I was able to put her in reverse and get her out of harms way. I was then able to make it back to the house safety. Any help would be greatly appr3ciated!
ndkid275 #1376095 09/06/2020 3:15 AM
Rear brake locking up is probably oil soaked shoes, caused by leaking axle bearing seals. You would think that greasy shoes wouldn't grab, but they definitely do.
ndkid275 #1376107 09/06/2020 3:44 AM
Hello All you Stovebolters!!
So I have a new to me 1949 1 Ton Chevy Truck! She was shipped down from Salt Lake City, 3 weeks ago. I took her out for a short drive and I think that the back passenger brake locked up as I was pulling out of a drive. I was able to put her in reverse and park her out of harms way. With her in reverse it released the brake. I was able to make it home safely. So what’s a girl got to do? Thanks for your input!
ndkid275 #1376109 09/06/2020 3:56 AM
Does a 1 ton have a star screw in the back To back the pads off like the 1/2 ton so we can take the drum off? If not, what am are we looking for and where? Sorry, first time dealing with a 1 ton truck.
Chris
ndkid275 #1376110 09/06/2020 4:57 AM
Fox Offline
On a one ton’s rear, on either side where the brake line enters the wheel cylinder on the backing plate, there are 2 hex heads. These run through the backing plate and are used to turn the toothed adjuster for the shoes on the inside. In my opinion, these are soooooo much easier to work with than the stupid little hole you have to stick your brake tool/screwdriver in, then fiddle/guess which way to turn to back off.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
ndkid275 #1376112 09/06/2020 5:17 AM
Emergency brake cable if used may stick and is difficult to go forward but does go backwards easier.1 ton may be different than a half ton
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
ndkid275 #1376113 09/06/2020 5:44 AM
Thank you for your input!!
ndkid275 #1376183 09/06/2020 9:51 PM
A leaking wheel cylinder can also cause this type problem. The brake fluid contaminates the brake shoes and makes them grab.
Rusty
ndkid275 #1376199 09/07/2020 12:03 AM
F Online: Content
Can the rear drum on a 1 ton be just pulled off once the wheel is removed like on a 1/2 ton or is there some retainer to prevent that? If no retainer then just pull the drum and see what it looks like.
Ed
ndkid275 #1376325 09/08/2020 12:11 AM
We drove it today. No issues until Pam used the parking brake, then it was all problems after that.
Chris
ndkid275 #1376327 09/08/2020 12:52 AM
Just curious does the parking brake have a leaver by the shifter and does the parking brake use a drum Separate from the rear brakes.
"The Journey"
Follow in the DITY
ndkid275 #1376329 09/08/2020 1:16 AM
I didn’t get to look at it.
