| | | Forums66 Topics128,096 Posts1,056,482 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2000 Posts: 199 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 199 | I see where it is said the difference between the 12 and 6 volt starters coincides with the flywheel tooth count. Why would I have 2 1954 trucks (apparently original with 6V everything) with the higher tooth count flywheels and smaller diameter gears on the starters that match with black tags not red?
Can I get the “12 volt” starter rebuilt to 6 v specifications so I don’t have to swap my clutch and flywheel? I know I can swap the truck to 12v. I just don’t feel like it!
Thanks. | | | | | Joined: Feb 2004 Posts: 29,831 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,831 | Normally, a "black label" 6V starter will have an armature diameter of about 5/8", and it will be matched up with a 139 tooth flywheel. The 1955-up "red label" starter will have a shaft diameter close to 1/2", and the correct flywheel will have 168 teeth. BOTH starter drives have 9 teeth, but the tooth pitch will be slightly different. It might be possible to mix and match parts to get a 6V housing and field coils combined with a 12V armature and drive gear, but I have my doubts that it would crank at the proper speed with a 6V battery. Jerry
| | | | | Joined: Apr 2000 Posts: 199 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 199 | I’ll have to run the number on the starter tag. Maybe someone previously mixed and matched. | | |
