0 members (), 191 guests, and 2 robots.
Topics128,089
Posts1,056,141
Members48,436
#137600 03/26/2007 1:18 AM
Junior Member
Junior Member
have a 1948 gmc 1/2 ton pickup. looking for advice on how to center up the rear end that has
a paralle 4 link and it also has air bags. it has a 355 small block with a t400 trans that is in the truck already. have not got drive shaft yet. any suggestions would be great.
thanks
#137601 03/26/2007 1:44 AM
Panhard bar, Watts linkage, Wob-link and Mumford link are the most common linkages for lateral support.
#137602 03/26/2007 2:21 AM
Art Morrison makes all the above locating methods. In kits with all brackets rod-ends and bars needed for the do it your selfer.
www.artmorrison.com
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
#137603 03/29/2007 6:22 PM
Junior Member
Junior Member
I went with competition engineering's panhard kit on the 58. It comes with a chromemoly tube, weld-in bungs, rod ends and mounting brackets (which I had to modify) all for about $70.
'58 Apache: Camaro sub, 383 w/forced induction, 700R4 trans, 4-link w/floating 9" and un-altered sheetmetal.
#137604 04/01/2007 2:58 AM
I don't know what breed of rear you have but Morrison sells a panhard bar that is perfect fit for a nine inch rear. I think it sells for about $100. It's a bolt on to the third member and weld on the frame.
~Jim
#137605 04/02/2007 4:00 AM
Alston and Morrison both offer quality stuff. I lean a bit toward Alston's Chassisworks.
Evan
