2 members (Phak1, Pre '68 Dave),
215
Mod | | | Forums66 Topics128,095 Posts1,056,067 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 27 Junior Member | | Junior Member Joined: Dec 2005 Posts: 27 | have a 1948 gmc 1/2 ton pickup. looking for advice on how to center up the rear end that has a paralle 4 link and it also has air bags. it has a 355 small block with a t400 trans that is in the truck already. have not got drive shaft yet. any suggestions would be great.
thanks | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Panhard bar, Watts linkage, Wob-link and Mumford link are the most common linkages for lateral support. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Art Morrison makes all the above locating methods. In kits with all brackets rod-ends and bars needed for the do it your selfer. www.artmorrison.com | | | | | Joined: Oct 2005 Posts: 24 Junior Member | | Junior Member Joined: Oct 2005 Posts: 24 | I went with competition engineering's panhard kit on the 58. It comes with a chromemoly tube, weld-in bungs, rod ends and mounting brackets (which I had to modify) all for about $70.
'58 Apache: Camaro sub, 383 w/forced induction, 700R4 trans, 4-link w/floating 9" and un-altered sheetmetal.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I don't know what breed of rear you have but Morrison sells a panhard bar that is perfect fit for a nine inch rear. I think it sells for about $100. It's a bolt on to the third member and weld on the frame.
~Jim
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Alston and Morrison both offer quality stuff. I lean a bit toward Alston's Chassisworks.
Evan
