6 members (Oldpickupman, klhansen, 55shaker, TUTS 59, Quindel54, jay d), 119 guests, and 2 robots.
Topics128,195
Posts1,057,377
Members48,469
Hi all,
I am building a new moter for my 69 4x4
1972 4 bolt main block, forged 383 crank,
9.5 to 1 pistons(which ones should I use?)
Dart cast iron performnce heads.
What cam would you all recomend for most mid range power & tourq with out sacrificing top end power?
thanks Luke
Luke Dahlin
1946 Chevy 2 ton
1966 Chevy 2 ton
1969 Chevy 3/4 ton 4wd
http://www.stovebolt.com/gallery/dahlin_luke_1969.html]1969 Chevy 3/4 ton 4x4
Luke as far as pistons for your 383 I would use a hypereutectic piston with a pin height for the 5.7” 350 rod or an aftermarket 6.0” rod. Stay away from the shorter 400 rod.
The hypereutectic piston is almost as strong as a forged but can be fit a lot titer so they don’t rattle during warm-up like a forging will. They also seem to build a little more power because they reflect more of the heat back in to the chamber.
As for your cam I prefer Comp Cam’s give there tech line a call armed with this info.
1 How you want the vehicle to perform.
2 vehicle weight.
3 Gear ratio and tire size.
4 RPM you plan to run
And 5 if you can obtain a flow chart for them heads that would be great.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
When I needed to rebuild the 350 in a C20 Van.I used a ISKY "272"cam.It had a power range from idle all the way up to freeway speed.The gas milege was no worse than stock.Later when I towed a car trailer,it didn't care, just pulled it too.Oh,also had a Perfomer manifold.I've heard the Comp Cam 268 is good too.
