2 members (klhansen, Hotrod Lincoln), 89 guests, and 0 robots.
Topics128,050
Posts1,055,641
#1375584 09/02/2020 12:27 PM
Anybody know if these brake adjusters are available anywhere or anybody got any kicking around they would like to sell thanks rob
Will you tell us what these fit?
Harold
Corrected spelling computerdeath
Harold
These are for the rear Huck brakes on larger trucks where you use a socket to adjust, rather than a screw driver. It is called a pinion. These come up on Ebay occasionally. I do not think our usual vendors have these. Try putting an ad in the parts wanted forum.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
You've got it and thank you will check it out cheers rob
Harold46 #1375606 09/02/2020 3:10 PM
Light holders dad explained exactly thank u
Quote
No need to yell! blush
How do you get yelling out of a simple question?
Harold
Harold
I don’t understand either. Did you have your caps lock on?
Quote
No caps, Regular type, simple question.
So many people ask questions without giving the application. Makes it nearly impossible to help them without giving details. It is like going into the ER of a hospital and saying I need a quart of blood. Just take one out of storage and start the transfusion.
Harold
Harold
"Will you yell us what these fit?"
Harold"
(in the original post in this thread)
I posted a little joke about not needing to yell to/at us.
I have deleted that/my post.
I understand now. yahoo
It is hard to get a good typist these days.
I have corrected my original post. dance
Harold
Harold
Thanks Tim for the explanation. I was soooo confused. But that’s normal for me! dang
9
9 Offline
Ive got them shipping is going to be expensive, and you will have to buy entite backing plates as those are staked on
Karl j Townsend
You should probably verify the PN with your application, however those look a lot like the ones used on military trucks. (See image)
The GMC PN for the kit is 608438. They come up on auction sites like e-pay quite frequently. There is actually a listing for some now. Just do a search for "GMC" and "608438".
Best Regards....
9
9 Offline
You could also place a small amount of weld onto the worn teeth,thats what i did on mine,they were staked onto pinion so removal would have to be spot welded back
Karl j Townsend
