2 members (FAST55, Rusty Rod),
96
Mod | | | Forums66 Topics128,026 Posts1,055,404 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 27 | I'm having to replace me axles, bearings and seals on my Nova rear end. 2 questions, when I look in the axles tube I see rust in the tube walls. Should I remove the the rust somehow? Next since I have the rear torn down I noticed that there are bearings in the pumpkin. Should I replace them? If so what is involved does it take special tools etc.? | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Not only special tools but special know how as well. I would not attempt it. I am sure there are plenty of qualified shops near by that would do the work. There are guys here that do their own differential repair. They would probably tell you the same thing.
~Jim
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Red55, its been a long time since I did a rear end, simply because I did not need to I suppose but if you have a few of the right tools it can be done. Patience, and attention to what your doing. I'm sure someone here can guide you along the way. RUST: I would try to run some type wire brush up in the housing to dislodge all the rust you can to prevent it from later falling and getting into the bearing/seals as well as the rear end itself. | | | | | Joined: May 2005 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 27 | Big Chevy 3600,
Were did you get you disk brakes for the rear? | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | red55 those are 2002 Camaro/TransAm 12" LS1 rear discs. They bolt right on.
~Jim
| | | | | Joined: Sep 2004 Posts: 148 Member | | Member Joined: Sep 2004 Posts: 148 | details!?!?
so the calipers and brackets just bolt onto the flange from the rear end? what year is the rear?
also, do they have a parking brake?
i ask because i have an 8.5" 10-bolt from a nova, and have been looking for a cheap rear disc solution.
2003 ford lightning 1959 chevy 36
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | It's a 81 Camaro 8.5 10". It is my belief that all 78,79,80, & 81 10 bolts are the same. These 2002 Camaro/Firebird discs just bolt right up to the flange. It is a bolt on like it was made for it. The parking brake lever works very well and should be easy to set up to any config you need. I bought these on Ebay.
~Jim
| | | | | Joined: May 2005 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 27 | Bid Chevy 3600,
When I look at your Webshots I didn't see the e-brake. Does the calipers have e-brakes? Also you said you got them from Ebay. Did you buy them from a supplier or an individual? | | | | | Joined: Sep 2004 Posts: 148 Member | | Member Joined: Sep 2004 Posts: 148 | can they fit a 15" wheel, or is the minimum a 16"?
| | | | | Joined: Sep 2004 Posts: 148 Member | | Member Joined: Sep 2004 Posts: 148 | also, what front brakes are you using to keep the brake bias favorable?
i have a nova clip, and i was looking at the stainless steel brakes force 10 direct replacement calipers. they are a dual 43mm piston caliper that uses the stock 11" rotor. i am afraid that the brake bias will be too much to the rear, i guess i can compensate with a prop. valve, but i would rather find some bigger front brakes to match, that don't cost an arm and a leg.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Yes the calipers have an E-Brake lever (2 inches) that swings about 1.5" to stop. I bought these from an individual on Ebay. They will fit a 15" wheel and 16". A 14" will need some off set.
My front Discs came with my Heidt's IFS (5 lug) and will match the rear. Guys sorry I took so long to reply.
~Jim
