| | | Forums66 Topics128,113 Posts1,056,277 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | My new 350 crate engine will be delivered sometime next week. I have seen some discussion here about an oil prime pump. I notice that GM sells a pump. I assume you must replace the distributor with this rod that you attach like a drill bit and spin the shaft till you see oil somewhere. My question is can this be done while on a motor stand several days, weeks or months before cranking the engine. I fear that when the engine is installed(3100)I won't be able to fit the pump rod in for the firewall. :confused:
~Jim
| | | | | Joined: Dec 2006 Posts: 37 Member | | Member Joined: Dec 2006 Posts: 37 | you can prime it now and when your ready to drop it in give er another prime job | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | For best results, spin right before starting while turning the engine over. Turning the engine over ensures oil passages line up to oil all areas. That being said, there are plenty of engines started w/o any priming whatsoever, such as newer vehicles using crankshaft driven oil pumps. One trick which works if priming cannot be done is to pack the oil pump w/Vaseline, this makes sure the pump sucks oil as soon as the engine turns, the Vaseline melts at a low temp & mixes w/the oil easily. My $.02,,Brian | | | | | Joined: Mar 2007 Posts: 3,398 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,398 | If you prime the engine on the stand it will fill the oil galleies, the oil will drain back eventually though. After the engine is installed and ready to fire (timing set, fuel to the carb etc) you can disconnect the coil wire and turn the engine over this will again prime the system. If you are buying an engine from a reputable builder it should have been assembled correctly and not have any issues.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Mar 2007 Posts: 3,398 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,398 | Forgot to mention, you should always fill the oil filter prior to installing it, Chevy's pull oil from the filter first rather than the pan.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | Tuts is correct prime before installing then turn over before starting,,all should be fine...doc | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | "Forgot to mention, you should always fill the oil filter prior to installing it, Chevy's pull oil from the filter first rather than the pan."
Thanks guys. The one thing I would have forgotten would be to fill the oil filter.
~Jim
| | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | One thing that was not mentioned was that just spinning the pump with a drill will not properly prime an engine.You need to use a dist. housing (no gear or top portion) to direct the oil to the lifters.You can make one by cutting an old dist. housing so that you use the neck and shaft.Prime with a drill until the oil is at the rockers.If you look down the dist hole on your engine you will see an open hole that will dump the oil back into the pan.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | We used to have a tank that we could fill with oil and add air pressure too that we could screw into the oil line of the block. Add pressure and it would feed oil to all locations. Check oil level when done. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | GM sells an engine oil primer. From the looks of it, it must work like the distributor. It’s a rod and appears to have a gear at the end. I don't know what it sells for, probably 30.00. I may go ahead and get one.
~Jim
| | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | GTOW69....just noted your post and am getting ready to spin my freshly rebuilt hydraulic lifter 235 over in the morning. Was wondering if your advice was specific to the V8? I don't have any ports in my 235 block and was intending to pre-oil with just a rod with a flattened end. Just don't want to take any chances with oil starvation. Will fill up my full-flow remote oil filter and have installed a supplimentary engine compartment oil pressure gauge so I can monitor the pressure.
Dave | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | You should be ok Fla54Chevy3100.I was refering to V8's.Spin your rod slowly (always good advice! lol) in the direction of dist. rotation so it doesn't jump off.Watch the rocker shaft for oil and check for leaks(ie rear main,oil plugs,fittings etc)
