| | | Forums66 Topics128,109 Posts1,056,569 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | Are the gas tanks for 47 and 48 different for each series? Will a 1/2-ton tank fit a 3/4-ton? Some of the vendors advertise a tank that fits 1/2-tons Pickups, Suburbans, Panels and Canopies with no mention of other models. Seems to be some confusion about it. Thanks.
Professional Novice
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | Thanks Tim. I'm still confused. Glad I don't need one myself.
Professional Novice
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Frank, are you looking for any fuel tank that might fit?
You have a 1950 truck, but, you refer to a 47/48 tank? Into what year truck do you want to install the tank?
Do you want an original style/location tank?
Do you want an in-cab tank, or an under-bed (inside frame) tank (where I think the original 1947/48 tanks were installed)? | | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | Tim, I personally do not need a tank, as I don't have a truck now. Someone on another forum that I frequent was asking about a replacement tank for his 1947 3600. He bought a tank from one of the vendors that did not fit, and I was doing some research. Thank you.
Professional Novice
