1 members (klhansen), 65 guests, and 3 robots.
Topics128,090
Posts1,056,376
Members48,442
#1374554 08/23/2020 2:17 PM
Are the gas tanks for 47 and 48 different for each series? Will a 1/2-ton tank fit a 3/4-ton? Some of the vendors advertise a tank that fits 1/2-tons Pickups, Suburbans, Panels and Canopies with no mention of other models. Seems to be some confusion about it. Thanks.
Professional Novice
1929-1954 Master Parts Catalog3.001 TANK, Gasoline
Thanks Tim. I'm still confused. Glad I don't need one myself.
Professional Novice
Frank, are you looking for any fuel tank that might fit?
You have a 1950 truck, but, you refer to a 47/48 tank?
Into what year truck do you want to install the tank?
Do you want an original style/location tank?
Do you want an in-cab tank, or an under-bed (inside frame) tank (where I think the original 1947/48 tanks were installed)?
Tim, I personally do not need a tank, as I don't have a truck now. Someone on another forum that I frequent was asking about a replacement tank for his 1947 3600. He bought a tank from one of the vendors that did not fit, and I was doing some research. Thank you.
Professional Novice
