Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (walter74, 32Fordpuchoptop, Hotrod Lincoln, baldeagle, 51sub, NJC), 41 guests, and 3 robots.
Topics128,005
Posts1,055,255
Members48,418
#1374145 08/20/2020 1:45 PM
Tore down an all original all standard 1958 283 engine and it has one carburetor to manifold hold down bolt that is hollow. WHY?
Evan
coilover #1374147 08/20/2020 2:00 PM
I’m guessing vacuum supply for the washer pump.
My Blog
coilover #1374152 08/20/2020 3:00 PM
Carburetion specialist
Not sure about this application, but GM used hollow studs on tripowers on both Chevrolet and Pontiac with tripower for an additional vacuum take-off of manifold vacuum.
Jon.
The Carburetor Shop
coilover #1374153 08/20/2020 3:02 PM
I remember them but can’t recall what was hooked up to them.🛠
coilover #1374203 08/20/2020 11:23 PM
3B Offline
Hy Guys, that is a good memory test, but I remember them, connected to the distributor vacuum advance.
coilover #1374206 08/20/2020 11:36 PM
H Online: Content
That 283 engine used full manifold vacuum to the distributor for some reason, same as some of the early 327's. It's a nipple for the distributor vacuum hose.
