9 members (TexasA&M48Truck, walter74, 32Fordpuchoptop, JW51, Hotrod Lincoln, baldeagle, 51sub, NJC, 1 invisible),
42
Mod | | | Forums66 Topics128,005 Posts1,055,255 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Tore down an all original all standard 1958 283 engine and it has one carburetor to manifold hold down bolt that is hollow. WHY?
Evan
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I’m guessing vacuum supply for the washer pump.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | Not sure about this application, but GM used hollow studs on tripowers on both Chevrolet and Pontiac with tripower for an additional vacuum take-off of manifold vacuum.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | I remember them but can’t recall what was hooked up to them.ðŸ›
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Guys, that is a good memory test, but I remember them, connected to the distributor vacuum advance. | | | | | Joined: Feb 2004 Posts: 29,741 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,741 | That 283 engine used full manifold vacuum to the distributor for some reason, same as some of the early 327's. It's a nipple for the distributor vacuum hose. Jerry
