2 members (Peggy M, Simso), 291 guests, and 9 robots.
Topics128,077
Posts1,056,034
Members48,433
#1373883 08/18/2020 4:33 AM
Hello,
My name is Bill. I'mI just bought a 1958 Chevy Apache 3800. It has a dual rear end, hi/low gearing. Inline 6 with 4bbl water cooled holley.
Just wondering if the 3800 was typically a one ton and how to tell. The guy I bought it from said the rear end is heavier than stock because of the dump.
I also want to know if the body parts are the same as the half ton versions or different. Essentially any important differences would be appreciated.
[img]https://photos.app.goo.gl/mPsELfvZzVL9mFkYA[/img]
1958 Chevy Apache 3800 1 ton Stake/Dump Bed
Welcome to the Stovebolt madness! There is no cure! shake
As for questions, the Welcome Center is not the place to ask questions. Your questions will be better served in the Tons of Fun Forum. The Welcome Center is only visited by less than 1% of our membership.
Very nice truck. That looks like some aftermarket gear on that six, including 4Bbl Holley, Aluminum Intake, and Aluminum Valve Cover.
Welcome to the 'bolt. Nice truck. and as Horsen said, please ask questions in the forum that applies.
Another quality post.
Real Trucks Rattle
Rustbucket Ranch
Rustbucket Ranch
Welcome! And very nice truck! I have a '58 3800 as well. The vin tag should have a "3G" in it, stating its a 1 ton. The cab and front end is the same as a 1/2 ton
Linger on over to the 1 ton forum and post some pics, lots of good knowledge there smile https://www.stovebolt.com/ubbthreads/ubbthreads.php/forums/45/1/tons-o-fun.html
1949 Chevy 3100 (In the family since new)
1955.5 Chevy 3100 - in the DITY Gallery - (Dad's truck)
1955 Chevy 6500 - in Big Bolts - (Possible parts truck?)
1958 Chevy 3800 w/9 ft bed - in Project Journals - (Current project)
1959 Chevy Spartan 10400 - in Big Bolts
Can I switch the forum or just re-post?
Thank you! I'll get the hang of it asap!
Nice. Congrats. Some cool goodies on it too. Make sure pull that L/R wheel b4 venturing to far. Theres obviously something leaking back there. Axle seal, wheel cylinder?
24601
Welcome Bill! For now, just copy and paste your question into a new post in the 1-ton forum. We're pretty easy to get along with on this site. I hope ...
smile
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Bill, Welcome to the Stovebolt and congrats on your truck. Always wanted me a dump bed but never came across one when I was looking. Thanks for the pictures.....see you around the garage.
As John said, we'll leave this here so others can welcome you here but the garage forums is where it happens!!
Big Bolt Forum Moderator
welcome! guys, did the 1-ton have the 5-10 lug nut configuration?
Mike
Rustbucket Ranch
Rustbucket Ranch
The 1 tons are the 8 lug configuration
Professional Novice
One ton indeed. 3G on the vin plate
thanks frank, cool info
that is what I thought, so, 1 1/2 ton(or larger) axles on a 1 ton truck maybe.
Mike
