| | | Forums66 Topics128,089 Posts1,056,364 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | Will I have to trim my inter fenders to fit around the spring towers on the Mustang II kit on my 51 ?? Im not finished installing the steering linkage yet and Im still a little ways from putting the metal back on, I was just wondering if anyone has had a problem with this before ? Thanks Todd Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | Yeah, you'll have to trim out the inner fenders a little. I just put mine up there and marked where they needed to be cut out and then cut a little at a time 'til I cut out enough.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
| | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | I didn't have to trim my inner fenders with my Mustang II installation. They did just fit though. I used a TCI kit for our 53 1/2 ton. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I have read discussions on this topic from time occasionally it is mentioned how it is much easier to install fenders if you bolt up the inner fenders and grill etc. first. Has anyone here got an opinion on this?
~Jim
| | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | Big Chevy, We had the fenders, inner fenders and radiator support as a unit. Worked real well. Didn't have the grille on it though. Took 4 people to line it up though. We taped all edges not to scratch the paint. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | should you find that you do need to trim the inners you may want to add/ fasten to the inners some sort of heavy rubber type sheet of material so as to block out debris and allow the IFS to fully float up and down
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | I think its going to be minimum.. if any (about a 1/4") just around the spring tower. That's a good idea with the rubber Thanks Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | |
