4 members (52Carl, Gdads51, JW51, Bisbee), 40 guests, and 3 robots.
Topics128,062
Posts1,055,845
Members48,428
#137285 02/22/2007 2:12 AM
I have ordered my crate engine (350 HO w\700R4) and will need to choose what headers I will use. In order to avoid the space issues conventional wisdom has said I should use block huggers. IF so what block huggers. As a teenager we all wanted Hedman Hedders but what about today? Is there something better? My main concern is 1) a good fit with no leaks and 2) to dodge the steering column and 3) ceramic or some other material that resists corruption. Any good ideas.
~Jim
Hedman is still around, you might check out Sanderson, too. They make several kinds of block huggers, might be able to find a solution for your particular fitment.
Bill Burmeister
Used Patriot Ceramics myself. So far so good.
I have a set from Street and Performance, fit perfect on our 1953 half-ton.
Be sure to check if they will clear side motor mounts--some won't. Summit has a notation that a set (# SUM-G6090) it sells won't, says "must use front motor mounts". Learned the hard way.
Evan
Anonymous
Unregistered
Anonymous
Unregistered
The block hugger style look great but have a couple of drawbacks from my experience which include motor mount clearance issues, and spark plug clearance (Some require shorty plugs). I went with the Hedman shorty swept back style for my V8 application in the 54.
I like sanderson cast irons
#137292 02/22/2007 10:28 PM
Thats true about needing shorty plugs. Had to use Accel plugs so the boots wouldnt ride on the pipes.
Block huggers also choke off some of your bottom end power and torque. If you're looking for that tire chirp from first to second, find a way to shoehorn full length headers in there. I've heard tell that early Camaro headers work in TF trucks with little or no mods.
[b]1957 Chevy Big Window 3100[.b]
More pix in Picasa
It ain't broke 'til you can't fix it any more.
I'm using the Sumitt brand block huggers, had then coated and using the shorty plugs also. Got plenty of clearance, no motor mount issues either on my 350 in a '46 Panel
David
Just a firefighter,
Cleverly disguised as a responsible adult
'46 1/2 T Panel
1 Offline
Im using a set of block huggers from patriot ceramic coated, fit nice,
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
I would just make sure that you get the thickest flanges you can that will help the leak go away, and their are two types of headers one for Straight and one for angle, and I got a name brand header. or you can build your own, they kits for that too, hope this helps
if its not broke....you didn't drive it hard enough!
