| | | Forums66 Topics128,132 Posts1,056,376 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | We have a 51 Ford truck that came in with a worn fuel pump rod lobe on the camshaft. Barely moves the rod and replacing the cam is a b_tch on a flat head. Owner brought with him a Tanks Inc in tank efi pump and regulator kit with fuel return line. Should work and last a long time with the pump submerged in gasoline plus be way more quiet than a regular frame mounted electric pump. I've seen this set up a number of times on race cars but with a Holley high volume external rotary electric pump. Another option for our trucks?
Evan
| | | | | Joined: Mar 2014 Posts: 4,501 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,501 | Evan isn't that EFI pump a high pressure one? All of those I've seen produce at least 20 and some up to 60 psi. It will be more quiet but if used with a carburetor, I'm afraid anything more than about 5 wouldn't work well. I've been using a frame mounted pump for several years with good luck. The one I have produces about 2.5 psi and that works fine with a 235. The same pump is being sold on Amazon. https://www.amazon.com/gp/product/B00496RE82/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1I hate to suggest a Chinese-made product other than soy sauce, but I bought the first one of these in 1997 and replaced it in 2018.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | FORD? What’s up with talking Fords? I’ve noticed in several of the forums lately that discussing the F word has become the norm. Shame on y’all!
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Holley makes a fuel pressure regulator one can put online to keep pressure down to 3-5 psi.
Ed
| | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | FORD? What’s up with talking Fords? I’ve noticed in several of the forums lately that discussing the F word has become the norm. Shame on y’all! Wow, I didn't even notice this was a F*** question until you pointed it out.
1951 Chevy Panel Truck
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Well, I mentioned a 'Found on Road Dead' product that no-one else produces that I used on my '37 GMC, to enhance the performance of the GMC. I wouldn't hesitate to use that resource.
Ed
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Ed, Evan could have worded his post in such a way that the Ferd wasn’t the lead topic. Using parts from different makes to keep our trucks running is entirely acceptable. I personally own a Ferd but I don’t discuss it here, there are forums for every brand.
