2 members (stlcardinalsguy, moparguy), 77 guests, and 1 robot.
Topics128,132
Posts1,056,731
Members48,454
I need a clutch in my 1946 Chevy truck but I’m not sure if it’s a two ton or ton and a half. How can I tell, and do they use the same clutch? Thanks in advance for any info.
3B Offline
Hy Dennis67, welcome, judging by your picture your truck is a two ton, bolt on front hub cab. One and one half tons have an eight sided screw in front hub cap. hope that helps
Nice looking pair of trucks!
Welcome to the Bolt!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Thanks. I have owned these trucks for years, and always wondered about the ‘46. The clutch is weak in it, and I’m thinking it’s worth putting a clutch into it.
Have you changed the clutch? You won't know the clutch size until you pull it. Original was 10 3/4. I replaced mine with 11" also changing the flywheel. 11" kits are easy to come by.
