5 members (Rusted Nut, mick53, Wally / Montana, klhansen, lumbersawyer), 97 guests, and 2 robots.
Topics128,049
Posts1,055,740
#1371313 07/30/2020 1:54 PM
After discussing ignition key switch's a few days ago I got a little panicky and bought several Briggs & Stratton ones. However one came with the type with the thumb and pointer finger turn wings. Will this work on my 53-3100? Doc.
I believe I read somewhere that the key cylinders with the wing were used on 47 AD trucks, then GM removed the wing. If it fits, it should work fine.
I know that my family's 54 Chev station wagon had a raised tab the key went into (no wing/pointer), which won't work on a truck. It had key start with 3 positions and you could remove the key in the on position and it would still start and run the car. looked similar to the attached photo. Those won't fit an AD truck ignition lock.
Both styles will work. Both should have the release pin hole in the same place.
My Blog
I'm a little confused, the type you are showing klhasen will not work in an AD? Ed
They're for cars and later trucks. The Key was the same pattern thru '66, but they may not fit in the ignition switch body correctly. I don't know for sure.
I believe it was the 47-48 trucks that had a single wing/lever on them. The cylinders show as a different in the parts book.
The face style does not matter, it is the position of the pin releases hole that matters.
The picture above is a universal cylinder, and has holes for both the early (low hole), and later switches (high hole).
I forgot the year the hole was moved, I will try to find that.
My Blog
9
9 Offline
Nice pics!,hey brad whats the switch underdash left of column under amp gauge cluster?
Karl j Townsend
That is one of these slab sided switches, there are several versions and colors available and also a fog light (rare) that goes right next to it.
https://www.flickr.com/photos/advance-design_parts_co/8129447791/in/album-72157631868452754/
https://www.flickr.com/photos/advance-design_parts_co/8129466604/in/album-72157631868452754/
The switches came with the factory heaters and the dash is punched for their placement. Here is one that is included with a recirculating heater I own (NOS).
https://www.flickr.com/photos/advance-design_parts_co/8129444438/in/album-72157631868452754/
Another NOS heater.
https://www.flickr.com/photos/advance-design_parts_co/8129307001/in/album-72157631868452754/
Thanks guys, I can send it back if need to $ 45.., Looks the same as on my 62. Doc.
Decided to order the tumbler switch holder and keep the key tumbler. Thanks Brad. Ed
