1 members (Otto Skorzeny),
115
0
Mod | | | Forums66 Topics128,049 Posts1,055,549 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | Hi Folks,
'77 chevy van/truck front ends have a 5 on 5" bolt pattern. I am searching for a rotor to switch that to a 5 on 4 3/4" bolt pattern.
Any leads as to where I could find that are greatly appreciated.
Colin | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Napa catalog shows part number 85542 on 78 on back G10 vans. It doesn,t give the dimentions but it is all by it,self for that model. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Those vans never used the 5x4 3/4" pattern, only the 5x5". You'll most likely have to drill the stockers for the pattern. Perhaps a local machine shop can do it for you.
Bill Burmeister | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | I used to have a 77 chev van.It had 5x5"rotors | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | The van front end has the 5x5" pattern. My rearend is a camaro 5 on 4 3/4. I need the bolt pattern to match and was told that I could buy rotors with the bolt pattern I want.
Thanks. | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | Sorry,Colin.I misunderstood.Getting the fronts re-drilled would be an option | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Colin, they are around but I can't remember right now where I got mine. I bought the rotors to go on a Stang II spindle I put on my 37 so it would be 5 lug pattern like the rear Malibu axle. Hang tight. Someone will have the answer. | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | Still can't seem to find this.
anyone else?
Thanks | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | it only cost $25.00 to have my pacer rotors redrilled. money well spent in my opinion.....dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | the c10 rotors i have have reinforcement between the wheel studs.the holes would have to be welded up before new holes could be drilled. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Are you committed to using the Camaro rearend? Perhaps getting a diff that matches the front end might be better, you'll have better matched capacity and brakes, and the wheel pattern will match.
Bill Burmeister | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | I might have to look into getting them redrilled then. What shop, or type of shop, would/could do that?
I am commited to the camaro rear, lots of money into it, let alone a good ratio, disc brakes, and posi.
Appreciate it. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | You might look into having the Camaro axles redrilled instead of the front disks. If the disks have webs in the way, that might be a better option.
Another thought. Look for some of the unilug wheels that will fit both 5 x 4.75 and 5 x 5. I've got a set that will fit either with a change of lug nuts (no that isn't an offer to sell them). With wheels like those, or just one of them as a spare, you might not need to redrill either end.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | Thanks Steve,
Which bolt pattern has more readily available wheel types? When I go to a wheel/tire shop to buy new wheels, I want to have the most selection possible.
Colin | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Let's hope you find an easy way to avoid it but if you need rotors, spindles, or axles re-drilled I can do it for you.
Curt
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | Thanks Curt, we'll see what else I can find first.
I kind of figured it would be better to go to the 5 on 4 3/4.
Thanks. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by Colin: Which bolt pattern has more readily available wheel types? Oh I think the 5 x 4-3/4 is going to be the most common by far. But if you study a wheel catalog I think you'll find most wheels are available in multiple patterns. And really I think you only care that the wheels you want will fit your truck. Have you chosen wheels?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You might look at fitments for late rear drive Impala/Caprice. They used both patterns. Std Caprice had the 5 x 4 3/4, Police, taxi, and SS models had the 5 x 5.
Bill Burmeister | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I stand corrected. Just checked out sites for 3 of the big names for wheels. None have a dual pattern the has 5x4 3/4 and 5x5. Lots of 5x4 3/4 and 5x4 1/2 though. Uni-lug might be the best choice, most likely Cragar or Halibrand, but they are high $$$.
Bill Burmeister | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Colin, I had a thought this morning about your problem. Here's my idea-Instead of redrilling rotors or trying to find non-existant/hard to get dual pattern wheels, how about redrilling the rear axles for the 5x5 pattern, then use late RWD Caprice police/ Impala SS rotors? I think that the rotors are the same or at least close to the overall diameter of the Camaro peices, and they have the 5x5 pattern. Just a thought.
Bill Burmeister | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | That's definantly an option Bill, thanks.
I'm still crossing my fingers for a bolt on rotor with a 5 on 4 3/4 pattern, but...yeah know. | | |
