Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (baldeagle, 1 invisible), 35 guests, and 2 robots.
Topics128,005
Posts1,055,264
Members48,418
#1370192 07/22/2020 6:03 PM
Getting ready for an engine and transmission pull in my '48 Chevy 1-Ton with a 216 and I'm looking for recommendations for a leveler. I see that some are rated @1500 lbs., others @ 2000 and am wondering if there is any real world difference between them. From your experiences, will the 1500 lb. rated levelers work well and which do you prefer?
Thanks, Jim
Eureka Jim #1370235 07/22/2020 9:41 PM
Yes, there is probably a real difference between them.
However, the engine plus the transmission probably does not weigh 1,000 lbs (the engine most likely weighs under 700 lbs)?
Eureka Jim #1370249 07/22/2020 11:39 PM
I'd rather have too much capacity than not enough.
Eureka Jim #1370439 07/24/2020 1:42 AM
Moderator
Moderator
2 Offline
Make sure you lube the leveling screw and run it the full length before you use it.
I also agree with Mark, get the heavier one. You may need it for a heavier engine sometime.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
2-Ton #1370461 07/24/2020 4:30 AM
Thanks for the replies and tips! I guess I'm questioning whether the Harbor freight one is actually 2000lb capacity when it seems comparable to many of the 1500lb ones like the one from the OTC brand. That's why I was hoping for some real world feedback from forum members on the ones they have used. If one is clearly better than the rest, that's the one I want. I also have a couple of engines to pull on some MGBs but I hope this is the last big truck I have to fool with.
Eureka Jim #1371524 07/31/2020 7:41 PM
1 Offline
Look for one with an Acme thread on the screw, not a "V" thread. The Acme is square shouldered and load bearing.
Joe D.
Eureka Jim #1371608 08/01/2020 1:54 PM
Crusty Old Sarge
Crusty Old Sarge
I was at a Northern Tool outlet the other day and saw this load leveler, its' rated at 1500 Lbs. It looked to be pretty solid built for the money. https://www.northerntool.com/shop/tools/product_200640936_200640936 , it's on sale as well.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Eureka Jim #1371617 08/01/2020 2:35 PM
That looks good, especially the price.
Eureka Jim #1371625 08/01/2020 3:00 PM
Used one just like that to put the V8 in my ‘61 C-10 without removing any body panels.🛠
Moderated by  MNSmith
