4 members (Gdads51, TUTS 59, Hush, 1 invisible), 115 guests, and 4 robots.
Topics128,266
Posts1,058,318
Members48,485
#1343935 01/28/2020 12:15 AM
Hi, what is the little 4 amp fuse for? I think it say's buss sfe 4 it is a little worn to read between my eyes and a magnifying glass I think that is what it say's. Thanks for the help. Steve P.S. The P.O. had nothing wired to the contacts in that part of the fuse panel.
3B Online: Content
3 Online: Content
Hy Steve1940, I haven't looked it up but my thought is radio fuse?
Thanks for the reply the fuse box has a fuse labeled radio. This spot has 5 empty spades above the small 4 amp fuse with no wires on it upper left side.
Do you believe that the fuse panel is original to the truck? Can you post a picture of it? I'm almost convinced to put a fuse block in my '58 and would like to see what it looks like.
1958 Chevrolet 3600 NAPCO 4x4 Apache
"Calvin"
I took it out and did add a new fuse panel. Glad I did it was real corroded don't need any fires.
