| | | Forums66 Topics128,049 Posts1,055,661 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 85 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 85 | Hi, what is the little 4 amp fuse for? I think it say's buss sfe 4 it is a little worn to read between my eyes and a magnifying glass I think that is what it say's. Thanks for the help. Steve P.S. The P.O. had nothing wired to the contacts in that part of the fuse panel.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Steve1940, I haven't looked it up but my thought is radio fuse? | | | | | Joined: Mar 2011 Posts: 85 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 85 | Thanks for the reply the fuse box has a fuse labeled radio. This spot has 5 empty spades above the small 4 amp fuse with no wires on it upper left side. | | | | | Joined: Feb 2008 Posts: 108 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 108 | Do you believe that the fuse panel is original to the truck? Can you post a picture of it? I'm almost convinced to put a fuse block in my '58 and would like to see what it looks like. | | | | | Joined: Mar 2011 Posts: 85 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 85 | I took it out and did add a new fuse panel. Glad I did it was real corroded don't need any fires. | | |
