3 members (Napco Man, dunfire, 68ironhead), 214 guests, and 2 robots.
Topics128,081
Posts1,055,955
Members48,430
#1343935 01/28/2020 12:15 AM
Hi, what is the little 4 amp fuse for? I think it say's buss sfe 4 it is a little worn to read between my eyes and a magnifying glass I think that is what it say's. Thanks for the help. Steve P.S. The P.O. had nothing wired to the contacts in that part of the fuse panel.
3B Offline
Hy Steve1940, I haven't looked it up but my thought is radio fuse?
Thanks for the reply the fuse box has a fuse labeled radio. This spot has 5 empty spades above the small 4 amp fuse with no wires on it upper left side.
Do you believe that the fuse panel is original to the truck? Can you post a picture of it? I'm almost convinced to put a fuse block in my '58 and would like to see what it looks like.
1958 Chevrolet 3600 NAPCO 4x4 Apache
"Calvin"
I took it out and did add a new fuse panel. Glad I did it was real corroded don't need any fires.
