Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
9 members (oldsteve, Mr Bailey, cmayna, 216wny, baldeagle, frogfarmer, JW51, Peggy M, 1 invisible), 40 guests, and 1 robot.
Topics128,005
Posts1,055,261
Members48,418
#1367068 06/30/2020 12:40 AM
Hello fellow golfers.
Tryin to pull the harmonic balancer off of a 270 engine in a 1950 GMC 350 model truck?
In a bad spot and I can’t tell what the threaded holes are?
Anyone know what the thread is for the two holes to pull the damper?Thanks again for the knowledge!
Brian
1952 GMC model 473 dump truck
1951 Chevy 1500 stepside
Sir Searchalot
Sir Searchalot
Get a 5/16 or a 3/8 bolt and try. Use a mirror. Don't know if fine or course thread. Does it have a bolt holding to crankshaft? I think some 270's did. Either way still needs a puller.
Took center bolt out.
Tried 3/8-16 That’s not it
Tried 5/16 coarse thread–- that’s not it, too small a diameter
Seems like I need a 3/8 fine thread maybe...
Have puller... just missin that bolt size in my set....😞
Brian
It's probably a 3/8-16 with some rust and crud in the threads. That's what a 216 , 235, and 261 all have, and I'm pretty sure those balancers will interchange with some GMC's. Try using a thread chaser to clean up the threads, but don't force it. I like to take a tap that's too dull to cut threads any more and grind the sharp points off the threads to make a chaser. I pulled a 216 balancer yesterday- - - -3/8-16. Chevy V8's use 3/8-24 threads in the 3 puller holes.
Sir Searchalot
Sir Searchalot
Sometimes they used fine threads on puller places, stronger for that use.
This balancer has a thru bolt goin thru it from side to side perpendicular to crankshaft snout ...
Took out the small set screw and tried to punch pin thru but hits edge of pulley.... too much to even force past...?
Any suggestions how this balancer comes off?
