2 members (Gdads51, 1 invisible),
118
8
Mod | | | Forums66 Topics128,088 Posts1,056,124 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 67 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 67 | Anybody have any ideas for separating pitman arm from box? I tried: - Gear puller - Banging the dang thing. - Propane torch.
Ron A | | | | | Joined: Feb 2004 Posts: 29,798 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,798 | There is a very heavy duty puller called- - - -wait for it- - - -a "Pitman Arm Puller"! The splined, tapered shaft on the steering gear, and the corresponding splined taper on the arm form a very tight fit. I usually use a 3/4" drive impact wrench on the puller. A lot of them actually have a couple of bolts that keep the puller jaws from spreading out and slipping off. Some auto parts stores will rent that type of tool, with a big security deposit. Jerry
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I have also used a fork type device between the arm and case, careful on the case.
Ed
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I have used this and this. No problems with either device. | | | | | Joined: Jul 2014 Posts: 1,289 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,289 | I used the very same type tool Tim refers to in his post. It worked like a charm on my 1954 3604 (3/4 ton) truck.
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | I'd let you borrow my pitman arm puller, if you lived a little closer. You should have no problem finding one locally.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
