5 members (treegrower, Bill Hanlon, Hotrod Lincoln, HandyAndy, FAST55), 186 guests, and 7 robots.
Topics128,077
Posts1,056,015
Members48,433
Anybody have any ideas for separating pitman arm from box?
I tried:
- Gear puller
- Banging the dang thing.
- Propane torch.
Ron A
H Online: Content
There is a very heavy duty puller called- - - -wait for it- - - -a "Pitman Arm Puller"! The splined, tapered shaft on the steering gear, and the corresponding splined taper on the arm form a very tight fit. I usually use a 3/4" drive impact wrench on the puller. A lot of them actually have a couple of bolts that keep the puller jaws from spreading out and slipping off. Some auto parts stores will rent that type of tool, with a big security deposit.
Crusing in the Passing Lane
I have also used a fork type device between the arm and case, careful on the case.
Ed
I have used
this and this.
No problems with either device.
I used the very same type tool Tim refers to in his post. It worked like a charm on my 1954 3604 (3/4 ton) truck.
Ron - - Dusty53
1954 Chevy 3604
I'd let you borrow my pitman arm puller, if you lived a little closer. You should have no problem finding one locally.
Craig
