| | | Forums66 Topics128,031 Posts1,055,433 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 110 | I have a 46 Chevy truck. I only have one mirror on an arm outside the driver side window. Did they have a mirror on the driver side or inside the truck?
Dan Mascheck Wharton, TX | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Dan, the single outside mirror was standard, either of the others were optional
Bill | | | | | Joined: Nov 2006 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 110 | What do you use on your truck. Just the single mirror on teh drivers side, or did you add one inside and one on the passenger side?
Dan | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | my 46 GMC was a 1.5T - it had some 50's west coasters outside, and I never did anything about an inside mirror as it was a dumper ... loaded the inside mirror wouldn't do much
Bill | | | | | Joined: Nov 2006 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 110 | Bill,
My new truck is only a puny half ton, but I love it! I just got home early from Christmas at the ranch and drove it around for an hour or so. Makes me feel good all over and especially with everyone on the road looking!
Where there extra optional mirrors you could buy on a 46 from the factory, or was it something you did yourself as an add on?
It has been modified and is not a stock truck. Actually I bought it that way and would haev preffered the old 6 with the 3 soeed onteh floor. The second owner before me decided to hop it up a bit..What a shame, but it is so unique. If you would like to see it drop me a line with your email address and I'll send you some pictures.
Merry Christmas!!!
Dan | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | my truck is 54 1/2 ton and i like the uncluttered look so i put peep mirrors on the doors. i had to use a glue on convex on the passenger side to get it focused. Ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | Dan everynow and then the inside mirrors are avail on ebay, I don't know of a repo being made as of yet. The outside mirror arms attached to the upper door hinge. There are aftermarket ones being made. The passanger side arm is longer than the drivers side they mount under the hinge pin and they have a small set screw in the rear of the bracket to keep it from moving.
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
| | | | | Joined: Nov 2006 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 110 | Thanks for the info about the mirrors! Although I imagine you could use many different inside mirrors although they may not look period. I will try to find one for the passenger side for safety purpose!!
Dan | | |
