2 members (J Lucas, pauld), 123 guests, and 2 robots.
Topics128,183
Posts1,057,263
Members48,467
Hey all, picked up this 1951 Chevy 3100 here in San Diego this January and have been having a blast with it.
Seems like a great community here looking forward to sharing some stories and maybe getting your help along the way.
First steps in breaking down the engine for a tune-up. Previous owners had swapped in a small block 350. Looks to be a relatively new crate motor, should be fine for me.
Taking my time, cleaning things up as I go. Lots of degreasing and repainting.
Decided to fill in the firewall while things are out of the way. Lots of welding and grinding. In hindsight I should have bought those patch panels that cover the whole thing.
Sprayed the engine bay black
New alternator, belts, Holley 4150C 670CFM Street Avenger, Aircleaner, covers, gaskets. Shined up nicely!
Loving the way this turned out.
Wohoo! Looks like you've been busy.
How long did all that take?
'59 Chevy Suburban, NAPCO
About two months to do the full engine and bay.
Wasn't happy with the gap to the new radiator. Fired up the CNC machine and fabricated a small patch panel to close it off. No need for a radiator shroud this way.
Onto electrical. Found melted wires in a few places while doing inspection so I decided to pull all new wiring and relays.
Parking brake removed and fabricated a new electric one. Used a 225lb linear actuator. One end is bolted to the frame and the other pulls the cable. An electrical switch inside turns it on/off.
Fixed the battery box and installed a fresh battery.
Got some help restoring the steel wheels. 15x7 front, 15x8 rear. Went with 225/75/15 and 235/75/15 tires.
Back to interior. Fabricated a mount to hold some small speakers. These Micca COVO-S are the perfect size and have coaxial tweeters. For their size, they produce a very full sound. Much better response than typical car audio open baffle speakers.
80's Jaguar front clip. New shocks and power steering rack. The old ones were shot.
Also cleaned up the hubs
Stripped down the cab interior
The tank was in very good shape. Decided to keep it in the cab for now but will prob move it under the bed later. Stripped and painted with truck bed liner for now. Hides the imperfections nicely and will disappear with the carpet.
Stripped the seat frame and hardware. Also resprayed the vinyl seat to all black.
Lots and lots more sanding on the cab.
Prepped and shot the cab rear. Using a satin medium grey metallic. It's a bit cooler of a tone than the original but will give the truck a slightly updated look.
Same paint on the doors
One of the window rollers had broken. Used the lathe to turn a new one from delrin.
Restored an old bermuda bell that grandpa used to have in his shop. Will be nice to have something from him on the truck, I'm sure he would have loved fixing this thing up.
Previous owner had shaved the dash where the old radio was located. Reworked the area to get the contours right knowing the new metallic paint will show lots of flake there.
Interior Paint Done!
Sound Deadner and carpet on the rear of the cab to quiet things down.
Subwoofer mounted under the seat just to round out the system. Nothing too loud.
Couldn't get the old steering wheel hub off and couldn't go get a puller late at night. Welded up a quick fix.
Moving to the floor with the sound deadner.
Gauges test fit and stereo testing completed. Hid the radio in the glovebox.
New rear window
Tried to do the windshield last night and couldn't get the gasket to lip up over the cab. Anyone tried it recently? Where did you order your gasket from? I'm curious if some suppliers may be slightly different size or softer rubber?
Nice work. Do it once, do it right!
The electric parking brake makes me laugh! I wonder if you could set it up for hill start assist, or auto turn off when you press the gas?
I have that same makita drill, soo awesome. Where'd you get the baby CNC?
Makita 18v set has been fantastic. I've had them since they came out without any issues. Might even get their new cordless mower soon.
Found the CNC on craigslist here locally. It's been a fantastic tool toy for little projects around the shop.
Moderated by  Phak1
