9 members (Hotrod Lincoln, Mike B, Chev4t6, cmayna, Chip O, Guitplayer, KCMongo, Wayne67vert, oldieoldie), 70 guests, and 6 robots.
Topics128,180
Posts1,057,153
Members48,464
Page 172 of 177 1 2 … 170 171 172 173 174 176 177
Chassis grease . smile
Got around to doing my "CHEAP" oil change yesterday. Some months back our local Pepboys went out of business. I made a couple trips there and I bought all the Castrol 5W-30 motor oil (10 quarts) they had plus what was left of the Transmax DEX/MERC (5 quarts) transmission fluid they had. With everything I bought it ended up being about $2 a quart for the oil. The Purolator filter was $1. $13 dollar oil change. Not to bad.
1949 5 Window 3100
Follow in the DITY
Veteran of the USAF
My Website
I’ve been restoring my Fulton 800 visor. Disassembled, cleaned, straightened, and installed all new stainless steel bolts and nuts. It was missing the stainless steel clamps & barrel nuts that attach to the center windshield divider. It was cheaper to order two new complete brackets than just those two missing parts. The new brackets arrived yesterday. Hoping to install the visor this weekend.
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
Replaced the clutch and went for a ride. Man that sure felt good, hadn't been out for almost 3 months.
Tommy
59 apache 1/2t
261 short stepside
I started up for the first time the Chevy 327 in my 48 3600 I have been building.
327 in my 48 3600
My wife surprised me, and washed my 55.2 truck today.
Brian
1955.2 3100 Truck
I got my Cat Whiskers in the doors installed, in-dash speaker wired up and installed, and put on the new glove box door and speaker grille. Heading out today to pick up an antenna.
1949 5 Window 3100
Follow in the DITY
Veteran of the USAF
My Website
Got the Fulton Sun Visor, and rear fenders on my GMC COE Wrecker.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Lookin’ good Sparky. That thing is a beast!!
Chuck
1941 Chevy coupe
That is awesome. Looks great.
Got my antenna mounted today under the truck. I made a bracket and mounted it to one of the seat bolts. The antenna lays horizontal running from front to back.
1949 5 Window 3100
Follow in the DITY
Veteran of the USAF
My Website
Got the driver's side kick panel beat into submission, fitted and prepped the floor and rocker for welding in. Welded a patch on the firewall.
With the kick panel hammered into shape, I had another productive day. Got the rocker and floor panel and the front cab mount welded in. Had to back up a little as I had repaired the floor at the left rear door pillar and tacked it in place about 1/4 inch too low. Cut out those welds and persuaded the floor to the correct position, then proceeded to get the floor and rocker in position for welding. Still need to finish the welds on the floor, but it's not going anywhere at the moment. I had left the old reinforcement at the tranny opening and once I got the floor tacked in place, took that out and welded in the new reinforcement. Got in the 70's today so knocked off early as I was getting sweaty. Still got in 5-1/2 hours though.
Real professional work Kevin. Lookin’ good!
Chuck
1941 Chevy coupe
Yeah, really solid work there Kevin.
Time consuming to say the least too.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Thanks guys.
As far as time consuming, I'd have to agree for sure. I was just thinking about a target of getting it on the road on my truck's 70th birthday next spring. I think I'll have to get my tail in gear to meet that schedule. wink
Looks great Kevin, my in-progress projects always look like a war zone until I get 'em finished and covered up somehow!
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
If you want to see a war zone, that was my shop till I cleaned it up a bit today. Took the day off of actual restoration and moved some things so I could move. wink
It was nice and cool this morning, so I decided to tinker on the truck. I cleaned, gapped, and reinstalled all the plugs. Tightened a bunch of bolts under the hood. Looked for the hole in the inner fender to mount my butterfly type heater hose holder and found none (???). One thing led to another and I ended up cleaning the cab interior for the first time in 12 years. Took everything out, swept the floor, and then put things back in their place. I learned that the back cab corners are great storage places. 😄 Everything looks nice and tidy now.
San Antonio had a bad hailstorm last Tuesday evening. I was sweeping out the bed and noticed where a chunk of ping pong ball size hail went through the gallon of water I keep in the back. I’ve been amazed that my old truck didn’t sustain any hail damage at all, but my 2019 F**d Edge sitting next to it was peppered with hail damage. They don’t make ‘me like they used to.
Chuck
1941 Chevy coupe
Socket Breaker
Socket Breaker
Had a flat on the '65 C10... luckily I was at home.
Pulled some sort of metal thing out of my tire, plugged, aired it back up, remounted it. So far, so good.
old tires are fun?
-Woog
Recruited a new Bolter. Wyatt is 4. The occasion was a College graduation party for my youngest son, Alex, who is 22. When Alex was 4, I took the same picture of him in the same truck- my ‘46 GMC EC-101. Wyatt is my niece’s first child. He was thrilled. Of course, his ride was limited to a slow trip around our yard.
Gotta love the young-ins. They have an eye for good things. My granddaughters who are 8 and 10 were helping me clean up my 49 over the weekend.
1949 5 Window 3100
Follow in the DITY
Veteran of the USAF
My Website
Took the seat out of the '55.1 COE 5700 so I could get to the gas tank. Had to cut the straps out and removed the tank. The critters left their homes, with hickory and walnuts. Got it cleaned out and ordered tank straps and sending unit.
Got the wood floor screwed down just like building a head board now.[img]https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/download/Number/19017/filename/51 chevy.jpg[/img]
Took 1959 Apache on first shakedown run following many years of slow progress. Finally on road and making progress. Drove 30 miles after puttiing in a new aftermarket temperature gauge. Truck still need finishing touches but is able to go down road at this point.
1959 Apache 31
Good looking truck. Good to see it’s finally back on the road. Enjoy the fruits of your labor!
Chuck
1941 Chevy coupe
Installed Bed Sides on the 51...
John,
The bed on your truck looks fantastic, especially the wood. That looks much better than the steel bed floors so often seen. Tell us about your wheels; size, brand, etc.
Oldbolter
1959 Apache 3800 dually flat bed/dump with 261
1956 3800 dually flat bed/dump with 235
1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
Reminder to everyone, this thread is not for asking questions or idle back and forth chit chat. Post what YOU got done on YOUR bolt today. Use a separate post or other forums for the other stuff. Thanks.
It's not what I did to my truck, it's what it did to me! I have 3 new (small) holes in my hands and arm.
Another quality post.
Real Trucks Rattle
After getting a couple "new" speedometer heads that were junk, got a reman one from Jim carter, put it in, drove & check speed with GPS speedo app on phone. found the adapter I needed in my tool box. Ran it again, right on the money!
BC
1960 C60 pasture art
24601
24601
Finally ... I got to do something on the '49 today! I adjusted the parking brake ... woo hoo!!! Took all of 15 minutes, but at least it was something.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
...........john, I've always said at least 15 minutes a day will git r done......don't care what it is.
...............Now, what is your 15 minutes for the next week????
Crusty Old Sarge
Crusty Old Sarge
Disassembled the front spring packs to add a new main leaf from Classic Parts. Now waiting on spring clamps to come in so a can do the final assembly.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Mounted the bed (unfinished - needs a lot of work), after finishing up the cab. Realized the middle running board mount is bent - have to figure out how to fix that... Its bent up slightly (so its higher than the rest) as well as bent forward... no clue how it happened.
Someone likely backed over a big rock. frown I have 2 that are so bent they need replacing, the others can be straightened. Find a piece of pipe large enough to fit over the mount to use as a pry bar. Put a jack under the inside edge and pry it back down and toward the rear. You shouldn't need any heat.
Attached front hood emblem, one of the most difficult jobs yet ( gasket not right), feels like 111 degree temp. 99% humidity in Central Florida. Doc
24601
24601
Alvin -- my 15 minutes for next week will be a redo of the pbrake adjustment ... wink Apparently, I need to take out a little more slack.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
new running boards, laying under the truck and cutting off all those old rusty bolts wasnt that bad but man was I dirty, trouble is the Boards came from one place and the hardware from another so hopefully the bolts well get here tomarrow, good chance to run it up to the car wash and power wash as much as I could before a layer of under coat
woof359 Family 1952 3100 5 Window
Made the huge mistake of letting 54-3100 set for 6 weeks without starting. xc#xYgtr alcohol in gas. everything is new, tank,lines a perfectly rebuilt model"B" and runs like a sewing machine. Glass fuel bowl has tablespoon of water. This is Florida so all my work starts again, little 54 runs awful. Going to drive 16 miles to a WAWA and get white gas (no alcohol), Only going to use WAWA blue pump gas in everything built before 1972. Dang. Just to make this ol guy happy call your local WAWA and ask for a blue pump. Thats what I did today. Doc
