| | | Forums66 Topics128,059 Posts1,055,823 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 79 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 79 | I put a 1958 235 in a stock 1949 1/2 ton used a 216 water pump and blade new radiator, I know the fan sets low, and I know they have an adaptor plate to raise the pump and blade. I have not started the truck yet, but was thinking about an electric fan, but only have one inch between the radiator and fan shaft. has any body put a push fan in front of the radiator , to help cool ? Thanks | | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | I am using a pusher fan in the Texas heat on my 216. No issues. If you are asking for opinions, you will get a lot from both sides. I will say that my fan is loud when I am stopped but I don’t hear it on the highway.
Chris | | | | | Joined: Mar 2014 Posts: 4,482 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,482 | I have A/C and therefore I have a pull fan (no water pump fan) controlled by an adjustable thermostat and shroud (Old Air Products) and I also have a push fan in front for the A/C. When the A/C is on, both fans run. When A/C isn't on only the thermostat controlled puller works. Here in N. Texas we have summer apx 300 days a year. Good luck.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Mar 2014 Posts: 4,482 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,482 | One other thing I'll mention. I switched from the stock radiator to an aluminum radiator about 2 years ago. That made a huge change in the degree of heat/cool transfer. If you can use one of those, I'd highly suggest doing it.
| | | | | Joined: Dec 2007 Posts: 79 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 79 | OK Thanks, think I'll put a pusher fan in front of the radiator, just to be on the safe side.My other question , is what did you do withe the rods that brace the front clip that cross in front of the radiator ? Thanks | | | | | Joined: Mar 2014 Posts: 4,482 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,482 | You may have to get creative and modify (space forward) those a bit...or if your fan is one of the low profile models it may be able to fit underneath.
| | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | I used those rods to mount my fan onto. | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | I didn't know you could use an earlier 216 water pump in a later 235 (without Pre'68 Dave's adaptor plate). I thought you had to use a 235 pump which puts the impellar inside the block, either as a short shaft modification or moving the radiator. Could this be your problem? Kent | | | | | Joined: Dec 2007 Posts: 79 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 79 | It's a short shaft water pump,but uses a 216 fan blade . | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | Ted,thanks for the clarification. My '42 has a short shaft water pump and 216 blade. I have never had overheating problems and I am pulling mountain grades in 90 degree weather all the time. My COE also has a short shaft water pump with an aftermarket fan blade with 6 blades. It will start to get overheated but only when warm and pulling those same grades. That truck weighs twice what my 1/2 ton weighs but has never overheated to the extent of boiling over or other problems. With a clean block and clean radiator, while not ideal, you may do just fine as you are. The adaptor plate is probably the best way to go. Kent | | |
