2 members (klhansen, TUTS 59), 64 guests, and 2 robots.
Topics128,066
Posts1,055,873
Members48,428
#1362074 05/26/2020 8:40 PM
I put a 1958 235 in a stock 1949 1/2 ton used a 216 water pump and blade new radiator, I know the fan sets low, and I know they have an adaptor plate to raise the pump and blade. I have not started the truck yet, but was thinking about an electric fan, but only have one inch between the radiator and fan shaft. has any body put a push fan in front of the radiator , to help cool ? Thanks
Ted Skidmore #1362115 05/26/2020 11:58 PM
I am using a pusher fan in the Texas heat on my 216. No issues. If you are asking for opinions, you will get a lot from both sides. I will say that my fan is loud when I am stopped but I don’t hear it on the highway.
Chris
Ted Skidmore #1362124 05/27/2020 12:24 AM
Moderator, Electrical Bay
I have A/C and therefore I have a pull fan (no water pump fan) controlled by an adjustable thermostat and shroud (Old Air Products) and I also have a push fan in front for the A/C. When the A/C is on, both fans run. When A/C isn't on only the thermostat controlled puller works. Here in N. Texas we have summer apx 300 days a year. Good luck.
~ Jon
One other thing I'll mention. I switched from the stock radiator to an aluminum radiator about 2 years ago. That made a huge change in the degree of heat/cool transfer. If you can use one of those, I'd highly suggest doing it.
~ Jon
Ted Skidmore #1362195 05/27/2020 11:06 AM
OK Thanks, think I'll put a pusher fan in front of the radiator, just to be on the safe side.My other question , is what did you do withe the rods that brace the front clip that cross in front of the radiator ? Thanks
Ted Skidmore #1362204 05/27/2020 12:53 PM
You may have to get creative and modify (space forward) those a bit...or if your fan is one of the low profile models it may be able to fit underneath.
~ Jon
I used those rods to mount my fan onto.
I didn't know you could use an earlier 216 water pump in a later 235 (without Pre'68 Dave's adaptor plate). I thought you had to use a 235 pump which puts the impellar inside the block, either as a short shaft modification or moving the radiator. Could this be your problem?
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
It's a short shaft water pump,but uses a 216 fan blade .
Ted,thanks for the clarification. My '42 has a short shaft water pump and 216 blade. I have never had overheating problems and I am pulling mountain grades in 90 degree weather all the time. My COE also has a short shaft water pump with an aftermarket fan blade with 6 blades. It will start to get overheated but only when warm and pulling those same grades. That truck weighs twice what my 1/2 ton weighs but has never overheated to the extent of boiling over or other problems. With a clean block and clean radiator, while not ideal, you may do just fine as you are. The adaptor plate is probably the best way to go. Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1951 Chevy 1/2 ton
