1 members (Thomaslb),
138
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2019 Posts: 131 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 131 | So, while tinkering with the transmission I decided to drain the rear end and remove the back cover. I am encouraged by the condition of the fluid and gears and decided to replace the axle seals while I have it apart. However, as I'm working on stuff I spray PB Blaster on nuts and bolts in the area so I can remove them if need be. There are three bolts in the front part of the differential housing and I loosened them then tightened them back up. Now I have found out they are pinion assembly lock screws. Now I'm wondering if I've messed something up? Is there some sort of clearance or torque spec I may have changed? Thanks John | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | If all you did was loosen and then re-tightened them, I think your OK, just as long as you tightened them good and tight. If they have a lock washer you should be fine as long as the lock washers are flattened out. Chevrolet's 1938 Shop Manual Axles Car and 1/2 ton truck axles are virtually repaired the same way. | | |
