0 members (), 69 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
#1362113 05/26/2020 11:52 PM
' Offline
So, while tinkering with the transmission I decided to drain the rear end and remove the back cover. I am encouraged by the
condition of the fluid and gears and decided to replace the axle seals while I have it apart. However, as I'm working on stuff
I spray PB Blaster on nuts and bolts in the area so I can remove them if need be. There are three bolts in the front part of
the differential housing and I loosened them then tightened them back up. Now I have found out they are pinion assembly
lock screws. Now I'm wondering if I've messed something up? Is there some sort of clearance or torque spec I may have
changed?
If all you did was loosen and then re-tightened them, I think your OK, just as long as you tightened them good and tight.
If they have a lock washer you should be fine as long as the lock washers are flattened out.
Chevrolet's 1938 Shop Manual Axles
Car and 1/2 ton truck axles are virtually repaired the same way.
