| | | Forums66 Topics128,048 Posts1,055,663 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2017 Posts: 5 'Bolter | | 'Bolter Joined: Jun 2017 Posts: 5 | A common occurrence on the advanced design models is for the drivers door to snag something and over extend the opening of the door resulting in a vertical crease in the cowl. I have a 54 Chev 2 ton dump with this problem and not being an autobody man was wondering if this is easy to correct should I decide at some future point to paint the truck. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | If the cowl is not rusted out, most of them are, a good body man may be able to "pull" it back out. If not, an outer cowl panel may be in order.....and be sure the door check is in good shape or it will swing wide and happen again! | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Every single old AD I’ve come across has had this damage. | | |
